Just a quick conceptual question
  • Thread starter Thread starter psilovethomas
    Conceptual
In a cylindrical space station rotating with constant angular velocity, the angular acceleration is indeed zero. This is because constant angular velocity implies no change in the rate of rotation. The astronaut, located at the perimeter, experiences this constant motion without any angular acceleration. The discussion highlights the distinction between angular and linear motion, but confirms the initial understanding that angular acceleration remains zero in this scenario. Overall, the concept of angular acceleration being zero is affirmed in the context of constant angular velocity.
psilovethomas
Is angular acceleration zero in this situation?
A cylindrical space station located in distant space, rotates with constant angular velocity about its axis. An astronaut rotates with the station and is located at the perimeter, a distance R from the axis.
Sure sounds like it to me. (It says 'constant angular velocity'.)
Doc Al,
Thanks for your response. I'm pretty confident in that answer as well. However, I began second-guessing myself because everything seems to different when it's angular and not linear.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
