Is the Twin Paradox Really Solved by Considering Acceleration?
In summary, the conversation discusses a thought experiment involving stopwatches and a car traveling at close to the speed of light. The question is raised about which stopwatch, the one on the car or the two on the ground, would measure a longer time for the trip. The explanation is that the signal between the stopwatches and the car would take time to travel, causing a difference in the measured time. The conversation also brings up the Twin Paradox and how the car's acceleration would affect the measurement of time.
khashayar
Hey Guys
I'm kinda new to relativity. I've worked really hard to understand the idea but there are still some thought going in my head trying to convince me that it doesn't make sense or I don't understand it. I was wondering if you can help me.
So here is my first problem regarding special relativity. Sorry that it's long but i had to explain the thought experiment.
In the twin paradox the problem is solved by invoving accelaration needed for the traveler to come back and arguing that the traveler is not in one inertia frame of reference at all time. Now let’s consider the following scenario. Suppose we have three identical stopwatches, and a car that can travel at speeds close to speed of light. One of the stop watches is placed at the start point of the track and another at the finish line. The third stop watch is installed on the car. Let’s assume that the road is perfectly straight and flat and that the stop watches are designed such that as soon as they meet they turn each other on if they were off and off if they were on. Also let all the stopwatches to be initially off.
The driver starts at some point far from the start point accelerating and reaches a speed close to that of light before he reaches the start line. As soon as he passes the start line both stopwatches start counting. When he reaches the finish line the stopwatch at the finish line starts counting and the stopwatch on the car stops. Driver slows down and brings the stop watch back to us. Meanwhile we have picked the other two stop watches from the start line and finish line. We stop both of them at the same time. Subtracting the time on the first stopwatch from the second one we have the time that took the car to travel from start to finish line from our point of view. The stopwatch on the car on the other hand should have the time measured from the driver’s point of view for completing the drive.
Since the stop watch installed on the car was not working while the driver was accelerating or slowing down it could not be affected by acceleration, and also we assume that the other two stop watches are brought together at really low speeds with almost zero acceleration. Also there was no communication between the driver and the observer involved to obtain the results.
Now the question is, “Which of the values is greater? The one measured by the stopwatch on the car, or the one obtained from subtracting the values shown by the other two stopwatches.” Suppose that we say since the car was in motion with respect to the observer the value shown by the stopwatch on the car is smaller, but then the driver can claim that he was not in motion and it was the observer and everything else which were moving at that speed in the oposit direction.
I used Lorentz_Einstein trasformations to find the time needed for the trip from two different points of view, but my results were crazy. They were telling me no matter what the time frrom observers poit of view is longer than the time recorded by the car. Did I make a mistake somewhere? Or is it simply because the action of stop watches being turned on and off happenes in the same space coordinate with respect to the car frame of reference?
Can someone help me please?
Thanks
The car should indeed have a longer time. The reason? As you said, the stopwatches affect each other. Well, since they cannot send an instaneous signal to each other, they must communicate at the most at light speed. Since the car is going very close to light speed as it passed the first stopwatch (or vice versa from the car's point of view) It will take time for the signal to catch up and start the starting stopwatch, and again when it passes the final one it will take time for the signal to affect the car stopwatch to turn it off. So thus the car signal will indeed be longer as it should.
In fact, this is no paradox that I can see, unless I am somehow missing the main point of it and visualizing the thought experiment wrong. So perhaps others can verify this?
Brad_Ad23 I do understand your explanation. However the thought experiment is designed in such a way that the distance between the car's stop watch and the other two stop watches as they pass each other is almost zero so the signal travel between the two passing each other takes almost zero time. I try to think of it as the stop watch on the car hitting the other two stop watches start/stop buttons gently as it passes by them.
Put that way, it would change my explination.
Since that is the case, it falls back to the same explination as the Twin's paradox. Because the car accelerates, the symmetry will be broken, regardless of whether the clock is on or not, it is time itself that slows. Still, I can't seem to find a way to show this. It could be some form of system entanglement that is occurring.
I better wait and see if any other people come up with explinations.
The stopwatch in the car will measure less time.
From the drivers POV:
Case 1:
The car deccelerates before the two stopwatches are brought together.
One of the peculiar things about accelerations is that the rate of time observed on distant clocks varies by how far away the clock is and in which direction. In particular, during the deceleration, he observes time running much faster for the start stopwatch than the finish stopwatch, fast enough to make up for the slowdown due to time dilation.
Case 2:
The car deccelerates after the two stopwatches are brought together.
I think the key is that when velocities are near the speed of light, slight differences can lead to large percentile differences in time dilation... but I don't have the time atm to sit down and draw up the space-time diagrams to see for sure what's going on.
Case 3:
The stop watches at the start line and finish line are stopped simultaneously before they are moved together, and before the ship deccelerates. (This can be done by just allowing for the light signal propagation delay time between them.)
Then you come up against the "Failure of Simultaneity", Where, by the two clock's frame, they stop at the same instant, but from the frame of the ship's clock, one continues to run after the other stops, accumulating the proper time difference.
So could this be accurately described by saying that bringing the car to a stop in order to compare watches should be viewed as an acceleration which brings the car into a common frame of refference with the other two watches? That is the key event, right; the car changing from one inertial frame of reference to another? If the car kept moving, the driver would always measure the clocks on the track to be slow, and the observer on the track would always measure the clock in the car to be slow?
The car's stopwatch will read less time.
In the stationary frame (the two external stopwatches), the time measured will be L/v, where L is the distance to the finish line and v is the car's velocity.
In the moving (car's) frame, the time measured will be L'/v, where L' is the (Lorentz-contracted) distance to the finish line.
Since L'<L, the car's watch will read less time. Specifically,
dt = (L-L')/v, where L' = L *(1-(v/c)^2)^1/2.
As far as the argument about inertial frames, the car does change reference frames, breaking the symmetry -just like in the "twin paradox" case.
thanks a lot guys
1. What is the "Kinda like Twin Paradox"?
The "Kinda like Twin Paradox" is a thought experiment in physics that explores the concepts of time dilation and relativity. It involves two identical twins, one who stays on Earth and one who travels through space at high speeds, and examines the differences in their aging processes.
2. How does the "Kinda like Twin Paradox" work?
In the thought experiment, one twin (Twin A) stays on Earth while the other twin (Twin B) travels away from Earth and then returns. Due to the effects of time dilation at high speeds, Twin B's aging process slows down relative to Twin A's. This means that when Twin B returns, they will be younger than Twin A.
3. Is the "Kinda like Twin Paradox" a real phenomenon?
The "Kinda like Twin Paradox" is a thought experiment and has not been observed in real life. However, the concepts of time dilation and relativity have been proven through experiments and are used in various technologies, such as GPS systems.
4. Can the "Kinda like Twin Paradox" be explained using Einstein's theory of relativity?
Yes, the "Kinda like Twin Paradox" can be explained using Einstein's theory of relativity. It demonstrates the principles of time dilation and the relativity of simultaneity, which are key concepts in the theory.
5. What are some potential implications of the "Kinda like Twin Paradox"?
The "Kinda like Twin Paradox" raises questions about the nature of time and aging, and how it may be affected by the speed of an object. It also has implications for space travel and the possibility of time travel. However, further research and experimentation would be needed to fully understand and explore these implications.
  • Other Physics Topics
