Kinetic energy of relativistic electrons
The discussion revolves around calculating the energy required to manipulate electrons in a barium aluminate metal and their kinetic energy at relativistic speeds. It is established that removing a mole of electrons requires approximately 96,300 joules, and one gram of electrons equates to about 1,836 moles. The kinetic energy of electrons accelerated to 0.9 times the speed of light (c) is influenced by a gamma factor of 2.29, which increases their effective mass and kinetic energy. The LINAC's specifications are discussed, particularly its power output and efficiency, to determine the energy needed to accelerate the electrons to relativistic speeds. Overall, the conversation emphasizes the complexities of electron acceleration and energy calculations in high-energy physics.
neptunone
Gentleman,
My questions are the following:
1.) If It takes 534 kJ to remove one mole of electrons from the atoms at the surface of a solid barium aluminate metal, how many kJ would it take to generate one gramm of electrons ?
2.) How much kinetic energy do one mole of electrons accelerated to relativistic speed (.9 c) have ?
3.) How much energy is required for the LINAC(1.1) to accelerate said mole of electrons to .9 c ?
Additional Info:
The LINAC consists of five Klystrons with the following characteristics:
C Band frequency Klystron E3783 –
Operating Frequency 2856 MHz
Peak Output Power 4.5 MW
Average Power 2.8 MW
Power efficiency 44 %
Gain (dB) 48 %
Pulse Length Duration 20 usec typical
Pulse Repetition 250 pps
Gun Voltage 130 KV
Beam Current 85 amps
Thank you for your help.
Sincerely
neptunone
Welcome to PF!
Hi neptunone! Welcome to PF! :smile:
(oh, and it's "Gentlemen" :wink:)
Show us what you've tried, and where you're stuck, and then we'll know how to help! :smile:
Using a work function of 1 eV per electron to pull it out of the cathode, it will take 96,300 joules to pull a mole of electrons out. So your barium titenate cathode must have a work function of 5.5 eV. The proton's mass is about 1 gram per mole, and the electron's mass is 1836 times less, so 1 gram of electrons is 1836 moles. 0.9 c equals a gamma of 2.29, so the total mass is 2.29 times as high, kinetic energy 1.29 times.
Is your 85 amps is the klystron beam current, and not the electron beam current? 2856 MHz is not very good for high electron beam current. (I used to work on a 2856 MHz Varian-built linac).
Dear tiny-tim, dear Gentlemen
Please forgive me for the typo. I would like to thank Bob S for his reply. That was very helpful.
0.9 c equals 2.29 gamma, the kinetic energy 1.29, so far so good.
That leaves the last question: How much energy is required for the LINAC (5 x 45 GeV, 4.5 MW each) to accelerate said mole of electrons to .9 c ?
Thank you very much for your time and patience.
Sincerely yours
neptunone
