How Is Kinetic Friction Calculated in Skier's Uphill Motion?
The discussion focuses on calculating the work done by kinetic friction and the magnitude of the kinetic frictional force for a skier moving uphill. The skier's mass is 64.9 kg, with an initial speed of 8.95 m/s and a final speed of 4.40 m/s after coasting 2.31 m up a 23.4° slope. The equations used include work-energy principles and the relationship between force, mass, and acceleration. Participants identify a potential sign error in their calculations, ultimately confirming the work done by friction as -1390 J. The conversation highlights common mistakes in physics problems, particularly regarding sign conventions.
onyxorca
A 64.9-kg skier coasts up a snow-covered hill that makes an angle of 23.4 ° with the horizontal. The initial speed of the skier is 8.95 m/s. After coasting a distance of 2.31 m up the slope, the speed of the skier is 4.40 m/s. (a) Find the work done by the kinetic frictional force that acts on the skis. (b) What is the magnitude of the kinetic frictional force?
http://edugen.wiley.com/edugen/courses/crs2216/art/qb/qu/c06/EAT_12258936060120_435296769488702.gif
W=FX 2K=mv^2 a=(v^2-v0^2)/2x
for (b) i used f=ma-mg sinθ,
or 1/2mv^2-1/2mv0^2-mgxsinθ for (a),
but neither was right...
looks good to me. What did you get?
I think there may be a sign error here?
\rm \Delta E = K_f - K_i + U_{f_{grav}}-U_{i_{grav}} = \frac{1}{2}m (v_f^2-v_i^2) +mg s Sin\theta = -1390J
Correct! thank you!
onyxorca said:
Correct! thank you!
You're welcome. If I had $1 for every time I've made a sign error in my lifetime, well, I'd own beach-front property in South Hampton. :smile:
