Calculating the Ratio of Planetary Orbital Periods
The discussion centers on calculating the ratio of the orbital periods of two planets, A and B, where planet B has double the mass and a semi-major axis twice that of planet A. The initial attempt incorrectly included the mass of the planets in the calculations, leading to an erroneous conclusion. It was clarified that according to Kepler's Third Law, the mass of the planets does not affect the ratio, as the relevant mass in the equation is that of the Sun. The correct approach shows that the ratio of the orbital periods is determined solely by the semi-major axes. Ultimately, the ratio of the orbital period of planet B to that of planet A is 2.
lizzyb
Two planets A and B, where B has twice the mass of A, orbit the Sun in elliptical orbits. The semi-major axis of the elliptical orbit of planet B is two times larger than the semi-major axis of the elliptical orbit of planet A.
What is the ratio of the orbital period of planet B to that of planet A?
T^2 = (\frac{4 \pi^2}{G M}) r^3
M_B = 2 M_A
a_B = 2 a_A
\frac{T_B}{T_A} = \frac{\sqrt{\frac{4 \pi^2}{G 2 M_A} 8 a_A^3}}{\sqrt{\frac{4 \pi^2}{G M_A} a_A^3}} = \sqrt{\frac{8}{2}} = \sqrt{ 4 } = 2
but that was wrong. ?
M_B = 2 M_A
a_B = 2 a_A
Planetary Mass is not a factor. Kepler's Third law states that T^2/a^3 is the same for all planets. The M in your equation is the mass of the sun.
AM
thank you.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
