Are There Deficiencies in Newton's Laws?
  • Thread starter Thread starter Questions999
    Laws Newton Short
Newton's laws have limitations, particularly in quantum mechanics where they do not apply. The equation F=ma is not valid in non-inertial reference frames, indicating that additional considerations are necessary. At velocities approaching the speed of light, special relativity must be used instead of Newtonian mechanics. These deficiencies highlight the need for more comprehensive theories in certain conditions. Understanding these limitations is crucial for accurate scientific analysis.
Questions999
So I am studying the laws of Newton and I am wondering,are there any deficiencies related to the laws?I mean,somewhere where I can't use them or anything?
Newton's laws do not apply on a quantum scale, if that's what your asking
F=ma doesn't hold in non-inertial reference frames and I believe you must use special relativity when you deal with velocities close to the speed of light.
