Let G be a finite group. Under what circumstances
  • Thread starter Thread starter Jamin2112
    Finite Group
Jamin2112
Let G be a finite group. Under what circumstances ...
... is that map δ:G→G defined by δ(x)=x2 an automorphism of F.
And automorphism δ:G→G is a bijective homomorphism.
The only circumstance I've so far found is that δ(x)≠x unless x=e. For
δ(x) = x -------> x2 = x -------> x = x2x-1 = xx-1 = e.
This seems to simple to be a sufficient condition, however.
Thoughts?
What is the definition of an automorphism?? What properties must \delta satisfy?
I stated the definition under relevant equations. And yes, I have a feeling where this is going ...
So... first write down the conditions for homomorphism and bijective?
... and then write them down again, carefully substituting the symbols of your current problem?
And then... ;)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
