Limitation first principle method
  • Thread starter Thread starter ezsmith
    Method Principle
ezsmith
Should be a simple question but its really tough for me because my lecturer had never teach me before about x^3
Anyway, the question is find the first derivative by using first principle method :
c) x^3+2x^2+1
I did dy/dx = lim h->0 but during the process I am stuck because I am pretty confused about the expand part especially during the power for 3
What do you mean by expanding for power 3? Assuming you want to expand (x+h)3, you need to multiply (x+h) thrice :wink: Or you can remember the result directly, or you can use the binomial theorem...
Edit : Do show your work, it'll be easier to help you out then :smile:
Yea, I meant by expanding the (x+h)3. I had managed to solve it using binomial theorem and it has saved me a lot of trouble. Thanks a lot Infinitum. Cheers :)
You're welcome! :smile:On a side note,
(a+b)3 is quite a commonly used identity, just like (a+b)2. It will surely help to memorize it.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
