How Does f(x) Behave as x Approaches 4 from Both Sides?
  • Thread starter kendal12
  • Tags
    Limits
In summary, the conversation discusses finding the limit of a function using a graphing calculator and identifying the value where the function fails to exist. The limit is found by observing the values of the function as x approaches the given value from both the left and right sides. In this case, the function fails to exist at x = 4 and the limit from the left is negative infinity while the limit from the right is positive infinity. This notation is written as lim_{x→4}f(x)=-∞. The concept of a limit is understanding what the value would be if it were possible for x to reach the given value. The conversation also explains how to graphically find the limit by observing the trend of the function as x approaches
kendal12
Ok, so here's the the problem:
"Use a graphing calculator to sketch the following function. Find the value c where the function fails to exist, and graphically find the limit of f(x) as x approaches c from the left and the right.
f(x)= 3/(x-4)
Ok, so what I don't understand is how I can define a limit from the left and right when the function in unbounded. I know that at 4 c fails to exist, so isn't that the limit from both sides?
It says to graphically show that.
Yeah, then it gives me a blank graph to draw the hyperbola, but then at the bottom it has:
lim f(x)=
x-->c-
and
lim f(x)=
x-->c+
What should I put here?
What does f(x) seems to go to when x approaches 4 from the left? i.e. when x succesively takes the values 3.9, 3.99, 3.999, ...?
Then do the same thing for the limit from the right. What does f(x) seems to go to when x approaches 4 from the right? i.e. when x succesively takes the values 4.1, 4.01, 4.001 ...?
it seems to go to infinity and negative infinity... is that what they're looking for? it seems too obvious
It's the opposite actually: negative infinity from the left and positive infinity from the right.
This is what "find the limit graphically" means. It means "what does the limit seems to be judging by the graph?".
f(x)= 3/(x-4)
the function fails to exist at 4 (c = 4). why? what happens to the graph, in other words, what are the values of f(x), as x gets closer and closer to (approaches) 4 from the left? for example, what are the values of f(x) when the values of x are 3.5, 3.8, 3.9, 3.95, 3.99, 3.995, 3.999,...and so on? as a limit, the values of x will get closer and closer to 4, but it will never reach 4. and as a limit, the values of f(x) keeps going in the negative direction of the y-axis. what is important to understand about limits is that the x values never reach the value that it is approaching. consequently, y = f(x) never reaches its corresponding value. think of a limit as a value that it is not possible, but if it would have been possible, that would have been the value. for example, it is not possible for x to reach 4, but if it would have been possible, x would have been 4, and f(x) would have been negative infinity.
this is the notation (how it is written):
lim_{x→4}f(x)=-∞
in other words, the limit of f(x) as x approaches 4 is equal to negative infinity.
you do the other half. what happens to the graph as x gets closer and closer to 4 from the right?
What is a limit from the left?
A limit from the left is a mathematical concept that represents the value that a function approaches as the input values approach a certain point from the left side. It is denoted by the notation "lim x→a-".
What is a limit from the right?
A limit from the right is a mathematical concept that represents the value that a function approaches as the input values approach a certain point from the right side. It is denoted by the notation "lim x→a+".
How is a limit from the left different from a limit from the right?
A limit from the left and a limit from the right differ in the direction from which the input values approach the point. In a limit from the left, the input values approach the point from the left side, while in a limit from the right, the input values approach the point from the right side.
What is the significance of limits from the left and right?
Limits from the left and right help us understand the behavior of a function at a specific point. They can help us determine if a function is continuous at that point and can also be used to find the value of a limit at that point.
How do you calculate limits from the left and right?
To calculate a limit from the left or right, we substitute values that are approaching the point from the respective side into the function and observe the resulting values. If the resulting values approach a specific value, then that value is the limit from that side. If the resulting values do not approach a specific value, then the limit does not exist.
