Calculating Coefficient of Linear Expansion for a Rod Using Temperature Change
In summary, the conversation involves a discussion about finding the coefficient of linear expansion for a material given its change in length and temperature. The participants also discuss using a table to find the coefficient for steel and provide equations to calculate the coefficient for the rod based on its change in length and the ruler's change in length.
aub
At 20° C, a rod is exactly 20.05 cm long on a steel ruler. Both the rod and the ruler are placed in an over at 250° C, where the rod now measure 20.11 cm on the same ruler. What is the coefficient of linear expansion for he material of which the rod is made?
ΔL = αLiΔT
ΔL= change in length
α= coefficient of linear expansion
ΔT= change in temperature
i can only think of one way (ΔT[rod]=ΔT[ruler]) in which i need α of the material of the ruler so it wrong. anyone can give me a hint?
hi aub! :wink:
aub said:
… in which i need α of the material of the ruler …
yes, you do need α for steel …
since the question specifies steel, i guess they want you to find it in a table, and use it :smile:
tiny-tim said:
hi aub! :wink:
i found α for steel
but i got stuck with the measurements since the ruler's 1 cm is now bigger
any help?
thanks
how much bigger (using α for steel)? :smile:
ΔL(steel)= αLiΔT= 11*10^-6*20.05*230= 0.0507 cm
i didnt get your point though..
ok, now that tells you how long 20.11 cm really is! :smile:
ΔL = αLiΔT
So ΔL[ruler]= α[steel]LΔT= 11*10^-6*20.11*230=-0.0508783
ΔL[rod]= -ΔL[ruler]+20.11-20.05= 9.1217*10^-3
α[rod]=ΔL[rod]/[L*ΔT]= 1.9*10^-6
right?
hi aub! :wink:
sorry, that's too difficult to read and check :redface:
can you please use the X2 icon just above the Reply box (to do the powers)
and also give the formulas you're using first, so that we can see what everything is! :smile:
tiny-tim said:
hi aub! :wink:
its one formula that I am using and i already did give it (ΔL = α*Li*ΔT)
So ΔL[ruler]= α[steel]LΔT= 11*10-6*20.11*230=-0.0508783
ΔL[rod]= -ΔL[ruler]+20.11-20.05= 9.1217*10-3
α[rod]=ΔL[rod]/[L*ΔT]= 1.9*10-6
What is linear expansion?
Linear expansion is the increase in length of a material when it is heated. This phenomenon is caused by the atoms in the material vibrating faster and taking up more space.
What is the coefficient of linear expansion?
The coefficient of linear expansion is a measure of how much a material will expand when heated. It is denoted by the Greek letter alpha (α) and is expressed in units of length per degree Celsius (or Kelvin).
How is the change in length of a rod calculated?
The change in length of a rod can be calculated using the formula: ΔL = αLΔT, where ΔL is the change in length, α is the coefficient of linear expansion, L is the original length of the rod, and ΔT is the change in temperature.
What factors affect the linear expansion of a rod?
The linear expansion of a rod is affected by the material it is made of, the length and cross-sectional area of the rod, and the temperature change. In general, materials with a higher coefficient of linear expansion will expand more when heated.
How is linear expansion used in everyday life?
Linear expansion is used in many everyday objects, such as thermometers, bimetallic strips, and bridges. It is also taken into account in construction, as buildings and roads need to be designed to accommodate the expansion and contraction caused by temperature changes.
