unirobotics
- 9
- 0
Undefined. Torque is not measured in Newtons.unirobotics said:So what is the actual answer in Newtons?
No, torques IS measured in Newtons.jbriggs444 said:Undefined. Torque is not measured in Newtons.
No, torque IS NOT measured in Newtons.unirobotics said:No, torques IS measured in Newtons.
See the edit I'd already added to #5 above.unirobotics said:I did not expect anyone to misunderstand. Actual NM is the abrv. But what is the answer, instead of haggling about a term
No. Torque does not vary with input linear speed.unirobotics said:Ok, apologies. However, the problem is does the torque not vary with the input linear speed? The 35,000 Newtons are moving at 200mm per minute. What happens if it moves say 200mm per 20 seconds?
0.32 Nm. Barring any frictional resistance, the torque you can draw off from a shaft matches, on average, the torque you put in.unirobotics said:Thank you for your answer. It helped a great deal. Instead of posting a new question could I perhaps procure help in this:
what is the torque generated by an input shaft turning at 2000 RPM with an input NM torque of 0.32NM?
NM : Nautical mileunirobotics said:Actual NM is the abrv.
