Linearising compound pendulum equation
The discussion revolves around the linearization of the compound pendulum equation T=2π√((K^2 + h^2)/(gh)), where K is a known constant. The original poster seeks to plot variables T and h to determine the value of g from the gradient of the resulting graph.
  • Participants explore methods to linearize the equation, with suggestions to manipulate the axes and consider Taylor approximations. There is discussion about the implications of K being a known constant and the challenges of measuring the pendulum's mass.
Some participants have offered insights on how to approach the linearization, while others express confusion regarding the setup and measurements involved. The original poster indicates a potential resolution after considering the graphing approach, though no consensus has been reached on the best method to linearize the equation.
There are constraints regarding the measurement of the pendulum's mass, which affects the ability to fully resolve the problem. The need for a Taylor approximation and the relationship between the variables are under discussion.
seboastien
Linearise T=2pi√(K^2 + h^2)/gh K is known constant
This is a compound pendulum equation, I want to plot some kind of formula with variable T against some kind of formula with variable H in order to find g from the gradient.
so I've got T/2pi all squared times g all substituted to x, h subbed to y and k^2 subbed to constant C and I've got the equation y^2 -yx + C=0 and tried to solve for y=x+β
I've tried implicit differentiation and it's gotten me nowhere
hi seboastien! :smile:
(try using the X2 button just above the Reply box :wink:)
if K is a known constant, can't you make one of the axes √(h2 + K2) ?
I would have to make the axis √((h^2 + K^2)/gh ) but that is a good point.
However, I would still like to know how I could linearise it further. I know that a taylor approximation is needed but I don't know how to, or what a value to choose
√(1 + (h2/K2) = 1 + (h2/K2)/2 + … :wink:
if h/K is small, then √(1 + (h2/K2)) = 1 + (h2/K2)/2 + …
hmmm, my only issue is that its the sqrt of K^2 + h^2 divided by gh
it also turns out that k is the radius of gyration and I have no scales to measure the pendulum's mass. I believe I need a y=mx + c where the y intercept will be determined by k, g by m, x by T and h by y.
is there any way of achieving this?
i'm confused :redface:
you said that K was known :confused:
That's because I thought I was allowed to measure the pendulums mass.
Don't worry I've worked it out...finally, turns out I've been overcomplicating things.
I'll just plot a graph of h^2 against h*T^2 the y intercept will be -k^2 and the gradient will be g/4pi^2.
Thanks anyway.
  • · Replies 32 ·
  • · Replies 31 ·
