Lorentz Transformation of Scalar Fields
waht
Working on an exercise from Srednicki's QFT and something is not clear.
Show that
[\varphi(x), M^{uv}] = \mathcal{L}^{uv} \varphi(x)
where
\mathcal{L}^{uv} = \frac{\hbar}{i} (x^u \partial^v - x^v \partial^u )
(1) U(\Lambda)^{-1} \varphi(x) U(\Lambda) = \varphi(\Lambda^{-1}x)
(2) \Lambda = 1 + \delta\omega
where \delta\omega [/itex] is an infinitesimal, and<br /> <br /> (3) U(\Lambda) = I + \frac{i}{2\hbar} \delta\omega_{uv} M^{uv}<br /> <br /> <h2>The Attempt at a Solution</h2><br /> <br /> Got the left side of (1) equal to<br /> <br /> \varphi(x) + \frac{i}{2\hbar}\delta\omega_{uv}[\varphi(x), M^{uv}]<br /> <br /> but not sure what to do with the right side and how to get the desired derivatives. I suspect<br /> it has something to do with the transformation (1) of its derivative, but so far no luck.<br /> <br /> U(\Lambda)^{-1} \partial^u \varphi(x) U(\Lambda) = \Lambda^{u}_{ p} \bar{\partial}^p \varphi(\Lambda^{-1}x)
1) What does Eq. (2) give you for the inverse of \Lambda?
2) use that expression to Taylor expand the right-hand side of your Eq. (1): that should also give you \phi(x) plus something...
Would it be
\Lambda^{-1} = 1 - \delta\omega
and taking the second order O(\delta\omega^2) to zero.
If I were to Taylor that then would get something like \varphi(0) + \varphi^{,}(0)
but that doesn't seem right
waht said:
Would it be
The first part is correct, the second isn't (but getting close): check your Taylor expansion: what's \phi(x+\epsilon)?
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
