Low torque homemade lathe-type machine
A motor with around 2.5kgcm torque and variable speeds of 60 to 180rpm can be used for a homemade lathe-type machine, ideally controlled by a foot pedal. The choice of motor type (AC or DC) and controller will depend on specific requirements such as stock length and swing. Proper support and alignment of the motor and stock feed apparatus are crucial for effective operation. Researching available components and building supplies is essential before making any purchases. Defining clear specifications will help in selecting the right equipment for the project.
mtranter
Hi
I am trying to find a motor that you could attach a chuck to and have somewhere around 2.5kgcm torque, with a speed variable between 60rpm and 180rpm, controllable with a foot pedal (smilar to a sewing machine pedal). Ideally there would be a clutch in there as well. Is there anything out there that might fit the bill?
Thanks,
Matt
What you ultimately end up obtaining will depend greatly on the specs that you set, other than the general drive motor and controller idea. I believe that you can find many lathes on the Internet that will provide the essential specs that you desire. What length of stock are planning for? What swing are you wanting to deal with? How will you maintain the stock feed? Once you have all of your requirements defined, and can purchase the motor (AC single/three phase, DC, etc.). You will then need to configure an appropriate support (height and swing) for the motor and stock feed apparatus, align them, and attach the chuck to the motor. You can always add one of several controller types that you might want. I am assuming that you know what you are doing and that you are on some sort of limited budget. Otherwise, I would recommend purchasing a unit that meets or exceeds your specifications (based upon your requirements).
Above all, research your available components and building supplies before you purchase them.
I hope this helps,
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
