Made an electromagnet, curious about how this works exactly.
An electromagnet's effectiveness is significantly enhanced by using an iron core, which increases the magnetic flux density generated by the coil. The strength of the magnetic field can be increased by either increasing the number of turns in the coil or the current flowing through it, but the relationship is not linear. Transformers require alternating current (AC) to function properly, as they rely on changing magnetic fields to induce voltage in a secondary coil; direct current (DC) does not create this effect. To change voltage in a DC circuit, methods like voltage regulators or switching mode power supplies are necessary. Understanding the principles of magnetic flux and its relationship to electric fields is crucial for grasping electromagnetism.
yanom
Hi, I'm a sophmore in high school, and I haven't taken the Physics course yet. So I'm a bit green. Anyway, I was playing around with an electromagnet I made with a nail and some 1mm wire, and I've got a few questions about the magnetism it generates:
-First, why does that iron core need to be in there? There's no current flowing through it, and from what I understand a coil already generates a magnetic field on it's own. But I can't do much with the coil itself, I've got to have that iron core.
-If I have a fixed energy supply, what makes a stronger magnetic through the coil: high voltage, low current or low voltage, high current?
-If I understand how transformers work correctly, they're simply two coils held together where one induces a current flow in another. So shouldn't a wire held up next to a powered coil show some sort of voltage? But if I do this, my multimeter can't detect any power in that second wire. So I don't understand this right. Do transformers require an iron core too?
Yes, that's true. A solenoid generates a magnetic field, but the flux intensity is greatly increased when a ferromagnetic material is introduced as the core. It happens because the magnetic field intensity is proportional to the turns of your coil and the current flowing. But, the magnetic flux density is related to the magnetic field intensity concerning the core material characteristics.
Maintaining the geometry and the core material, if you increase the number of turns or the current, the magnetic field intensity will increase as well. It's important to know that in real life the relation between magnetic field intensity and magnetic flux density is not linear. There are regions which can be modeled as such.
The ferromagnetic core has two purposes: increase the magnetic flux density magnitude and guide the flux lines within it (ideally). The voltage appears only when B (magnetic flux density) varies with time. If you are applying DC current, nothing will be noticed in the second coil, with a ferromagnetic core or not, unless you move the coil through a non uniform field, or varies the area where B is passing.
Replied inside the quote.
I'll give you some tips.
H - magnetic field intensity vector
N - turns
I - current
If you have a closed core with average length C, then you will have the following relation, excluding flux dispersion and a uniform magnetic field within the core:
|H|*C = N*I
B = u*H, considering a linear model.
u - core magnetic permeability
B - magnetic flux density vector
F = |B|*S, considering B uniform and perpendicular to the core cross section area.
F - Flux
S - core cross section area
V = d(N*F)/dt
V = voltage in a coil with N turns within a flux F.
So transformers only work with AC current? what do you do if you have to voltage-change in a DC-only circuit?
flux
uhh... what's that? :redface:
Yes, that's true. Increasing or decreasing voltage in a DC circuit is not so simple. You can use a voltage regulator which dissipates with resistors the additional voltage (very inefficient). On the other hand, if you want to increase the voltage, a more complex system such as a switching mode power supply should be used.
About flux: http://en.wikipedia.org/wiki/Flux
ok, thanks. So flux is flow through a surface area? Like water through a certain area filter?
Wait, how does magnetism "flow"? It isn't a type of waves/radiation, is it?:confused:
Exactly.
Magnetic fields and electric fields are related by the following Maxwell Equations:
E - Electric field intensity vector
H - Magnetic field intensity vector
B - Magnetic flux density vector
Jf - Free current density
Considering a linear relation between H and B in a space free of charge, you obtain the following:
That's an homogeneous wave equation. If you decompose the vector in three coordinates and solve the equations, you will obtain three wave functions.
Therefore, you will have a wave only when E or H varies in time.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
