What is the magnetic field produced by an electron beam in a cathodic ray tube?
In a cathodic ray tube, a circular electron beam with a diameter of 0.22 mm and a kinetic energy of 25 keV produces a magnetic field at a distance of 1.5 mm from its axis. The current generated by the beam, calculated from the flow of 5.6*10^14 electrons per second, is approximately 8.97 * 10^-5 Amperes. The discussion highlights the application of Ampere's law to determine the magnetic field, emphasizing that the shape of the magnetic field lines around a straight current is circular. The kinetic energy of the electrons is deemed irrelevant for this calculation, as the focus is on the current and its magnetic effects. Ultimately, the magnetic field produced by the beam is found to be 12 nT.
fishingspree2
In a cathodic ray tube, the canon launches a circular electron beam on the screen. The beam has a 0.22 mm diameter, the electrons have a kinetic energy of 25 keV and 5.6*10^14 electrons reach the screen each second. Find the magnetic field produced by the beam on a point located at a 1.5mm distance of the beam axis.
The answer is 12 nT
I know that the magnetic field of a circular arc is
B = (u*i*angle)/(4*Pi*distance) but in this case I don't have an angle so I am pretty sure this is not the correct formula
Also we could integrate using the biot savart rule but we don't have the limits of integration.
I have found the current by using the fact that 5.6*10^14 electrons reach the screen each second. By converting electrons to coulombs, I get 8.97 * 10^-5 Amperes. Then I am stuck, I have no idea how to continue
thank you
You should review Ampere's law. Particularly the integral form. By the way, do you remember the shape of the magnetic field line in the vicinity of a current flowing in a straight line?
A circle I believe?
I still can't do it =( I don't understand what to do with the kinetic energy... I can find the electrons velocity but it would only be useful in the formula F = q v x B and I don't think that would apply here
fishingspree2 said:
A circle I believe?
Yes, the magnetic field lines take the shape of a circle going around a current i that is traveling in a straight line.
Now do you know Ampere's law? You have already found the magnitude of the current. Ampere's law involves a line integral taken over a suitable path. This actually is a very simple problem once you check your textbook (or Wikipedia). You will have to simplify a dot product, but that should be no problem.
The kinetic energy is a red herring and F = qv X B is useless in this context.
