Magnetic field within cylinder using Ampere's Law
The discussion focuses on using Ampere's Law to demonstrate that the magnetic field strength inside a cylinder with a constant current density j is given by B = (mu-nought)*j*r/2. Participants clarify that the magnetic field is directed in the theta-hat direction, while components in the r-hat and z-hat directions should be zero. One user successfully proves the absence of the r-hat component using a closed cylinder and the principle that the flux through its surface is zero. However, they seek guidance on proving the absence of the z-hat component, leading to suggestions about using a rectangular surface to analyze the circulation of the magnetic field. The conversation emphasizes the distinction between applying Ampere's Law and Gauss's Law in this context.
Silversonic
Using Ampere's law, show that the magnetic field strength in a region within a cylinder, which has a constant current density j (flowing in the direction parallel to its axis), is equal to
It doesn't say specifically, but this is the field in the theta-hat direction - i.e. in the direction of the cylinder's axis of rotation. I can prove this easily and the actual question isn't the problem. I'm assuming that this question means I have to show that the magnetic field in the r-hat direction (radially outwards) and the z-hat direction (in the direction of the current flow) are both zero.
I can prove there is no component in the r-hat direction by taking an imaginary cylinder, placing it within and using the fact that the flux through the cylinders surface is always equal to zero.
However, how do I prove that there is no component in the z-hat direction? Any help/hints appreciated.
Did you try using the same reasoning? That is, finding a surface that would allow to calculate the circulation of z - component of the field?
What surface would I use? If I use a cylinder, that only tells me that the flux in the z-hat direction through one end is equal and opposite to the flux in the z-hat direction flowing through the other end - but it doesn't tell me that the magnetic field for that component is zero, only that the sum of the two fluxes flowing through the ends sums to zero.
Wait - it seems like you are using a Gauss law instead of Ampere's law. You need a circulation of B-field around the boundary of your surface. It will be proportional to the current going through the surface.
I used Ampere's law to find the direction of the field in the theta-hat direction, I haven't touched Gauss' law at all.
I used the fact that \intB.dS = 0, using a closed cylinder, to show that it is zero in the r-hat direction, but can't prove it for the z-hat direction.
Try a rectangle with one side placed inside the cylinder, parallel to the z-axis, and the opposite side outside of the cylinder.
