Magnetic fields/ force on conductors
To calculate the magnetic field (B) at a distance of 50 cm from a long straight conductor carrying a current of 1000A, the correct approach involves using the appropriate equation that relates B to the current, rather than focusing on force calculations. The discussion highlights the confusion between calculating magnetic force and magnetic field, emphasizing the need for a specific formula from textbooks or online resources. Participants suggest looking for the Biot-Savart law as a potential method to derive B. The initial attempt at a solution mistakenly used force equations, which are not applicable for this calculation. Understanding the correct relationship between current and magnetic field is crucial for solving the problem accurately.
alice emily
calculate a value for B at a distance of 50cm, in ,air, from a long straight cable carrying a current of 1000A.
F=Bqv=BIl
I=q\t = qv/l
F=LIB
i have not been able to calculate an answer as there are constantly two unknowns and i am unable o fine F.
i believe the answer is 4 x 10 to the -4 telsa
You're being asked to find magnetic field and not force due to the magnetic field, right?
The equations you wrote allow you to find the force due to a magnetic field, once you already know what B is. However, right now you're trying to find B due to the current. You need a different equation, that's hopefully in your book that relates B and current I.
yeah johnj7 is right. You need the proper equation. Look in your textbook for an equation relating B to a current carrying wire. Check online as well. If you're desperate and have learned what is known as the Biot-Savart law, you can derive B from there.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
