Calculating Magnetic Field for a Circular Wire with Given Parameters
The discussion focuses on calculating the magnetic field generated by a circular wire with specific parameters. The initial attempts at the solution incorrectly omitted the current in the magnetic field formula and miscalculated the contributions from multiple wires. Participants emphasize the importance of considering vector components and the correct positioning of the point where the magnetic field is measured. The correct approach involves using trigonometry to resolve the magnetic field vectors and ensuring the current is included in the calculations. Ultimately, the correct magnetic field value is confirmed to be 24 µT, highlighting the need for accurate application of formulas and vector addition.
riken9
Heres the question: http://imgur.com/aFJFxLa
B = μ0/2∏r
μ0 = 4∏*10^-7
Magnetic field = μ0/2∏r + μ0/2∏r
= μ0/2∏(0.05) + μ0/2∏(0.05)
= 4*10^-5
The answer is 24*10^-6 T. I need some assistance on what i may be doing wrong.
My 2nd attempt at question:
B = μ0/4∏*(5+5)Sin 53.1/(0.08)^2 <== this is still wrong.
Well first of all, you are fergetting something in your formula for the magnetic field...
check it (hint: it will have to depend also on the current, right??)
Then consider in which point you are computing the field (in order to be 5cm away from each wire) and draw the forces in that point... the apply correctly trigonometry (the fields will not be simply aligned, you will have to compute a sum of vectors) and here is the result
Opps I forgot to put the current in formula; but I assure you I used it. And can you explain mor about the point, can I pick a point outside the picture I provided, which is 5 cms away from each wire and forms 2 right angle triangles. Also which method should I be using the first one or the 2nd one (1st or 2nd attempt)
Actually no one of your attempts is correct (as far as I understand at least, it is difficult to see what is denominator and what is numerator but no problem).
Anyway OK for the fact that you find two right angle triangles. Then you have to compute the value of the field in that point (simply with your formula), and only then you compute (considering that the field vector is tangential to the circumference passing through your point) the components (you will have to compute the angles). Then the components in one direction will cancel while the components in another direction will add up. Do the sum and you're done. By the way, I got really ##24 \mu T##.
Isn't what I did with the 1st attempt correct, I just need to add angles and is the hypotense the magnetic field?
Ok, yes, if you compute correctly the components you are actually adding (using angles) and use the current, then yes, it is your first attempt
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
