Magnetic Flux Density at different points about a solenoid
ajhooger
For my physics investigation I am required to first find the theoretical magnetic flux denisty at different points about a solenoid. The points are outside the solenoid: along the axis but past the ends and; perpendicular to the centre of the solenoid but outside.
So far I have looked at many links to Biot-Savart law, but they only seem to show equations for a loop and not a solenoid.
I have tried for the point along the axis:
http://www.utc.edu/Faculty/Tatiana-Allen/Magfig4.gif
but it only works with in the confines of the solenoid.
I also tried:
http://www.utc.edu/Faculty/Tatiana-Allen/Magfig2.gif
but it doesn't work for the solenoid.
What I basically need is two equations, one for the axis, and, one for the points perpendicular to the centre.
i was looking for this same equation a few months ago, bloody hard thing to find but i found it!
for a thin shell solenoid use the equation found here: http://www.netdenizen.com/emagnettest/solenoids/?thinsolenoid
for a solenoid with a shell use the equation found here: http://www.netdenizen.com/emagnettest/solenoids/?solenoid
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
