Calculating Magnetic Flux Density in a Hollow Cylindrical Conductor
likephysics
π²³ ∞ ° → ~ µ ρ σ τ ω ∑ … √ ∫ ≤ ≥ ± ∃ · θ φ ψ Ω α β γ δ ∂ ∆ ∇ ε λ Λ Γ ô
An arbitrarily long hallow cylindrical electric conductor shown carries a static electric current density J=\hat{z}J0. Determine the magnetic flux density B in the hallow region of radius a. Your result should show that B is constant in this region.
∫B.dl = µ0I
current I = \hat{z}J0pi(b2-a2)
B. 2pia = µ0 \hat{z}J0pi(b2-a2)
B = µ0 \hat{z}J0(b2-a2) /2a
I am not sure about B.dl being B.2pi a
Utilize the relation
\vec{B}=\frac{\mu_0\vec{J}\times\vec{r}}{2}
and approach the problem with a uniform current distribution throughout the circle of radius b, plus a current in the opposite direction in the hole.
I am trying to do exactly that: +J current density in b and -J in region of radius a.
Add both to get result. But in the equation you mentioned, how to calculate the cross product.
seems a bit complicated. Can't I use just ∫B.dl = µ0I
Superposition of B within the hollow region:
\vec{B}=\vec{B_b}+\vec{B_a}
\vec{B}=\frac{\mu_0\vec{J}\times(\vec{r_b}-\vec{r_a})}{2}
So, what is
\vec{r_b}-\vec{r_a}
equivalent to?
ddddddddddddddddddddddddddddddd.
Can't believe I missed it.
I shall go shoot myself in the foot.
Before I do that, can you tell me how to solve Jxr for a single sphere problem.
Just do the cross product or is there some trick?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
