Radius of Circular Path Affected by Magnetic Force: Increase or Decrease?
When an electron moves in a magnetic field, its circular path's radius (r) is determined by the equation r = mv/Bq. As another electron moves faster in the same magnetic field, its velocity (v) increases, which affects the magnetic force (F) acting on it. Although the magnetic force increases with speed, the velocity's squared relationship in the centripetal force equation means that the increase in speed has a more significant impact, leading to an increase in the radius of the circular path. Thus, the radius of the path for the faster electron will increase compared to the slower one. The relationship between velocity and radius in a magnetic field indicates that higher speed results in a larger radius.
Gunman
An electron moves in a circular path in a vacuum under the influence of a magnetic field perpendicular to and into the paper.If there is another electron which moves with a higher speed in a circular path in the same B-field, state and explain how each of the following will be affected as compared to the first electron?
(c) The radius of the circular path
F = Bqv
B = flux density
q = charge
v = velocity of the charge
F(m) = Bqv
Since F(m) causes the centripetal acceleration of electron
F(m) = Bqv = mv^2/r
r = mv/Bq
Therefore it can be concluded that r increases as v increases?
But how can this be case as,
F(m) = Bqv, and F(m) increases as velocity of the charge increases
If F(m) increases, r would decrease as it is inversely proportional to F
in the equation F(m) = mv^2/r.
So would r increase or decrease if a faster electron moves in a circular path in a vacuum under the influence of a magnetic field perpendicular to and into the paper.
F = Bqv
B = flux density
q = charge
F(m) = Bqv
F(m) = Bqv = mv^2/r
r = mv/Bq
You have clearly put a lot of thought into this question, perhaps a little too much :wink:. Consider your final equation,
F = \frac{mv^2}{r}
And your final comment,
You are correct that the magnetic force increases, but you forget that the speed v has also increased. Notice that the speed is raised to the second power and therefore will have a much greater effect on the magnetic force that the radius since the radius is only raised to the fist power.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
