Magnitude of Electric Field in Cell Membrane?
The discussion focuses on calculating the magnitude of the electric field across a cell membrane, which has a potential difference of 0.060 V and a thickness of 9.00 x 10^-9 m. The formula used is E = V/r, where V is the voltage and r is the thickness. A participant initially calculated the electric field as 6.7E-6 V/m, but this was deemed incorrect due to the expectation of a larger value given the small thickness. The correct calculation should yield a much higher electric field strength, indicating a potential error in the exponent or arithmetic. The conversation emphasizes the importance of careful mathematical evaluation in physics problems.
rcmango
[SOLVED] magnitude of electric field.
The inner and outer surfaces of a cell membrane carry a negative and positive charge, respectively. Because of these charges, a potential difference of about 0.060 V exists across the membrane.
The thickness of the membrane is 9.00 x 10^-9 m. What is the magnitude of the electric field in the membrane?
in V/m
i believe the equation to be: E = V/r
not sure why .060 / 9.00 x 10^-9 would not work?
it says my answer of: 6.7E-6 is incorrect??
You are dividing a number by a VERY small number. This means that your answer should be a very big number. 6.7E-6 is not very big. Check your math. I think you may have made an sign error with your exponent.
Okay thanks, 6.7E6
Anytime.:smile:
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
