hummina
- 6
A skateboard axle is 8mm thick and typically 4140 steel. Can I make up for its hardness or other strength values with 1144 or even 1018 if I use a 20mm axle?
Welcome to the PF.hummina said:A skateboard axle is 8mm thick and typically 4140 steel. Can I make up for its hardness or other strength values with 1144 or even 1018 if I use a 20mm axle?
hummina said:Isn't there a formula for figuring the load ability of a shaft based on its mass or surface area and material?
