What is the acceleration of two masses on pulleys with constant tension?
  • Thread starter Karol
  • Tags
    Pulleys
In summary, the conversation discusses the acceleration of two masses at the ends of a system with N+2 masses. The rope on a weightless pulley has constant tension and the situation can be represented by two equations. The resulting acceleration is found to be (N-2)/(N+2)g, which is negative. However, further analysis reveals that the two end masses actually move downwards while the other N masses move upwards, resulting in a "lever" effect and a final acceleration of -(N/(2N+1))g.
Karol
1,380
All N+2 masses are m. what is the acceleration of the 2 masses at the ends.
The rope on a weightless pulley has constant tension.
The situation is the same as:
$$\left\{\begin{array}{l} Nmg-2T=Nma \\ T-mg=ma \end{array}\right.$$
$$\rightarrow~a=\frac{N-2}{N+2}g$$
$$N=1\rightarrow~a=-\frac{1}{3}g$$
And it's wrong
I wonder about your assumed equivalent system. Try the following thought experiment with the original system: Replace the two end masses with fixed supports so that the rope is fixed at those points and the system will be static. What would be the tension in the rope? Is it Nmg? Nmg/2? Something else?
If the accelerations of the end masses is a, kinematicly, what is the acceleration of each of the N middle masses?
I will denote as x and a the vertical displacement and acceleration of the 2 masses at the ends, and with y the displacement of each of the N middle masses:
$$2x=2Ny~~\rightarrow~~y=\frac{x}{N}~~\rightarrow~~\ddot y=\frac{a}{N}$$
$$\left\{\begin{array}{l} Nmg-2T=Nm\frac{a}{N} \\ T-mg=ma \end{array}\right.~~\rightarrow~~a=\frac{N-2}{3}g$$
That's not what I get. $$mg-2T=m\frac{a}{N}$$
Hi Karol. Instinctively it is tempting to think that the N masses must all contribute to the net force that the end masses experience. But if you look closely you'll see that by symmetry most of the N masses are balancing each other's contributions over the pulleys between them, and these upper pulleys are supported by the "ceiling". So in effect the "ceiling" is doing most of the "lifting".
I suggest that you focus on one general representative of the N masses to write your equation. I concur with @Chestermiller 's analysis.
Likes Chestermiller
The positive direction is upwards, a, the edge's acceleration is positive and ay, the acceleration of the other masses is negative:
$$\left\{\begin{array}{l} 2T-mg=-ma_y=-m\frac{a}{N} \\ T-mg=ma \end{array}\right.~~\rightarrow~~a=-\frac{N}{2N+1}g$$
Not good, a<0.
Not good, a<0.
Surprisingly, this is actually correct. The two end masses move down, and all the other masses move up. This is a "lever" effect.
Likes gneill
Thank you Haruspex and gneill. so only the 2 masses adjacent to the 2 outer masses contribute. the outer masses must hold half of the adjacent masses, ##\frac{1}{2}mg##, plus the acceleration of all the inner N mases
You're welcome. But I think you meant to thank Chestermiller rather than Haruspex. Although Haruspex is often very helpful, too!
Sorry, true... but thank you all...
What is the concept of "many masses on pulleys"?
The concept of "many masses on pulleys" refers to a system in which multiple masses are connected to each other via pulleys and a rope or cable. This system is often used to study the principles of mechanics and is commonly seen in physics experiments and demonstrations.
How do you calculate the tension in the rope or cable in a system of many masses on pulleys?
To calculate the tension in the rope or cable in a system of many masses on pulleys, you must first determine the total mass of the system. Then, using the principles of Newton's laws of motion and free-body diagrams, you can calculate the net force acting on each mass and the tension in the rope or cable connecting them.
What factors can affect the acceleration of a system of many masses on pulleys?
The acceleration of a system of many masses on pulleys can be affected by factors such as the mass of each individual object, the number of pulleys and ropes in the system, the angle of the pulleys, and the coefficient of friction between the objects and the surface they are on.
What is the difference between a fixed pulley and a movable pulley in a system of many masses on pulleys?
In a system of many masses on pulleys, a fixed pulley is attached to a stationary object while a movable pulley can move along with the objects it is connected to. The use of a movable pulley can change the direction of the force required to lift the objects, making it easier to lift heavy masses.
How does the number of pulleys in a system of many masses on pulleys affect the mechanical advantage?
The mechanical advantage of a system of many masses on pulleys increases with the number of pulleys used. As more pulleys are added, the amount of force needed to lift the masses decreases, making it easier to lift heavy objects. This is why systems of many masses on pulleys are often used in situations where a mechanical advantage is needed, such as in lifting heavy loads or moving objects over a distance.
