How Does Changing a Planet's Radius Affect Its Mass?
  • Thread starter Thread starter unseenoi
    Mass Radius
Changing a planet's radius affects its mass based on the volume and density relationship. If a planet's radius is one-fifth that of Earth, its volume is significantly reduced, calculated using the formula for the volume of a sphere. Assuming the same density as Earth, the mass can be determined by multiplying the volume ratio by Earth's mass. The discussion emphasizes understanding the density formula, where density equals mass divided by volume. The key takeaway is that mass is not directly proportional to radius but is influenced by volume and density.
unseenoi
I know this is a dumb question but if the radius of a planet is one-fifth of the Earth's radius. what is the mass of the planet.
Earth mass => 5.97 *1024
earth radius => 6.38 *106
my answer: 5.97 *1024(1/10)
unseenoi said:
I know this is a dumb question but if the radius of a planet is one-fifth of the Earth . what is the mass of the planet.
And incorrect.
If the radius is 1/5 and it has the same density as earth, then what would the mass be?
Think about the ratio of the volume between the 2 and then multiply that appropriately by Earth mass.
Can u please give me more details.
density = mass/volume --> \rho=m/v
What is the formula for determining the volume of a sphere? Given the Earth's radius, what is its volume?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
