Mass of cylinder using ang.velocity
  • Thread starter Thread starter bigtymer8700
    Cylinder Mass
The discussion focuses on calculating the mass of a solid uniform cylinder using angular velocity and energy conservation principles. The system involves a 3 kg stone tied to a string wrapped around the cylinder, which falls 2.5 m and reaches a speed of 3.5 m/s. The user correctly identifies the need to apply the rotational inertia formula I = 1/2 Mr^2 and the kinetic energy equation Kf = 1/2mv^2 + 1/2Iw^2. They derive angular velocity using the relationship v = rw, resulting in an angular velocity of 9.3 rad/s. The user expresses uncertainty about solving for the unknowns in the kinetic energy equation and seeks confirmation on their approach.
bigtymer8700
A light string is wrapped around the outer rim of a solid uniform cylinder of radius .375m that can rotate without friction about an axle through its center. A 3.00 kg stone is tied to the free end of the string When the system is released from rest, you determine that the stone reaches a speed of 3.50 m/s after having fallen 2.50m .
What is the mass of the cylinder?
Ive solved for:
F=M*a
3kg*9.8=29N
29N*2.5m=73.5J
i know its a solid cylinder so I=1/2 Mr^2 so i need to solve for the inertia. from here i got stuck i know i have to use
Kf=1/2mv^2+1/2Iw^2 i don't know where to go from here. do i solve for the angular velocity(w)? or Inertia?
i know v=rw so would w=v/r i could use 3.5m/s/.375m to get 9.3rad/s?
anyone know if I am doing this one rite?
i used the Ki + Ui=Kf + Uf
Ki=0
Ui=mgy=73.5J
Kf=1/2mv^2+1/2Iw^2
Uf=0
i got
73.5=1/2Iw^2+18.375 so
1/2(I)w^2=55.125J
im stuck on Kf where i have to solve for the two unknowns I* w* i used v=rw to solve for w is that correct?
got it
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
