Mass of sculpture given fm, mass, lengths etc
  • Thread starter Thread starter tg22542
    Fm Mass
The discussion revolves around calculating the mass of a sculpture suspended by a steel wire vibrating at a fundamental frequency of 97 Hz. Key equations include the wave velocity equation v = sqrt(T/μ) and the mass per unit length μ = m/L. Participants clarify that the tension in the wire is solely due to the weight of the sculpture, not affected by wind. Understanding the relationship between wave properties and tension is emphasized, particularly recognizing that the wire's displacement resembles half of a sine wave. The conversation highlights the importance of correctly interpreting variables in the equations to solve for the sculpture's mass.
tg22542
A heavy sculpture is suspended by a steel wire that is 91.0 cm long and has a mass of 5.40 g. In a strong wind, the wire hums at its fundamental frequency of 97 Hz. What is the mass of the sculpture?
v = sqrt(T/μ)
μ = m/L
I am pretty lost here. There is no velocity involved in the equation (I think) so I can't use the first equation, I tried messing around with the second equation and then plugging fm into v but no luck. Is there maybe an equation that I am missing here? Help!
You have not included the "experimental" equation, v = lambda f.
The "strong wind" is putting vibrational Energy into the wire, it is not blowing the sculpture sideways, which would increase the wire Tension.
So, the Tension is only caused by the sculpture weight mg.
the Wave excited by the string is resonating at the fundamental;
this means that the 2nd reflection reinforces the original wave; the wire displacement (transverse to its length) looks like ½ of a sine wave (node on both ends).
Once you recognize the wavelength, you can determine the wave velocity - then the Tension.
tg22542, it can lead you well astray if you remember equations but not what the variables in them stand for. What did you think v stood for in v = sqrt(T/μ)?
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
