Maximum acceleration of 1500 kg car on concrete surface?
The maximum acceleration of a 1500 kg car on a concrete surface, with two-thirds of its weight on the drive wheels and a static friction coefficient of 1, is calculated to be 6.53 m/s². This calculation is based on the formula F = ma, where the force is derived from the weight distribution. While the presence of a backward frictional force on the non-drive wheels could affect real-world performance, it can be ignored if the mass of the wheels is negligible. The provided answer of 6.53 m/s² is confirmed as correct. Understanding these dynamics is crucial for accurate vehicle performance assessments.
senpim
Two-thirds of the weight of a 1500 kg car rests on the drive wheels. What is the maximum acceleration of this car on a concrete surface?
μs = 1
F = ma[/B]
The answer I got is 6.53 m/s^2 , but I want to make sure the answer is correct.[/B]
Yes, your answer (2g/3) is correct.
In reality, there will also be a backwards frictional force on the other (non-drive) wheels to get them rotating, but if the mass of the wheels are negligible then this can be ignored.
