Max Mass for Cylinder to Roll Without Slipping | Cylinder and Mass System
The maximum mass m2 that can be attached to a uniform solid cylinder of mass m1=7.1 Kg, which rolls without slipping on a table with a coefficient of static friction U=0.202, can be determined using the equations of motion and torque. The relevant equations include Torque=I*alpha and F=ma, where I for the cylinder is Icylinder=1/2*mass*radius^2. The maximum acceleration a is derived as a=2*U*g, leading to the calculation of m2 in terms of known quantities.
  • Understanding of Newton's laws of motion
  • Familiarity with torque and rotational dynamics
  • Knowledge of static friction and its coefficients
  • Ability to manipulate algebraic equations to solve for unknowns
  • Study the application of Newton's 2nd law in rotational systems
  • Learn about the relationship between linear and angular acceleration
  • Explore the concept of limiting friction in mechanics
  • Investigate the dynamics of pulleys and tension in strings
Students in physics or engineering courses, educators teaching mechanics, and anyone interested in understanding the dynamics of rolling objects and static friction.
ecksee
The axle of a uniform solid cylinder of mass m1=7.1 Kg is attached to a string that runs over a massless, frictionless pulley. The other end of the string is attached to a mass m2. The coefficient of static friction between the cylinder and the table is U=0.202. What is the max mass m2 (in Kg) for which the cylinder will roll without slipping?
Torque=I*alpha
F=ma
a=alpha*radius
m2
Tension-m2*g=m2*a
a=(Tension-m2*g)/m2
m1
Torque=U*m1*g*radius=1/2*m1*radius^2*(a/radius)
a=2*U*g
System
2*U*g=(Tension-m2*g)/m2
See diagram:
I think you're making this more difficult than it needs to be! The question, worded in another way, is asking for the maximum force that can be exerted on the cylinder so that it rolls and does not slip. [hint: limiting friction]
ecksee said:
m2
Tension-m2*g=m2*a
a=(Tension-m2*g)/m2
Be careful with your signs: The tension is up, but the acceleration is down.
m1
a=2*U*g
Good. You've applied the condition for maximum static friction to find the maximum acceleration. Now use this to find the corresponding value of m2 that will produce such an acceleration.
You need one more equation: Apply Newton's 2nd law to the translation of m1. Your goal is find m2 in terms of known quantities (not in terms of tension).
I get this equation to be F=ma=T=m1*a
This doesn't really get me anywhere. Am I missing something?
Right. Now put it to work.
You found the acceleration using your second equation. Combine that result with your first equation and this one to solve for m2. (You'll need to correct the sign error in your first equation.)
  • · Replies 21 ·
  • · Replies 21 ·
