Maximizing Boat Trailer Capacity: Redesign Tips & Tricks for Heavy Loads
  • Thread starter Thread starter Chad Gilchrist
    Boat Trailer
This discussion focuses on redesigning a boat trailer to support a heavy load of approximately 20,000 lbs. The user aims to increase axle capacity and redistribute weight from the axles to the main aluminum I beams. Proposed solutions include designing and installing five new supports made from 3" square tubes to better distribute the load. The user seeks advice on the appropriate wall thickness for aluminum tubes and the strength of stainless steel cap screws for securing the supports.
  • Understanding of structural engineering principles related to load distribution
  • Familiarity with materials such as aluminum and steel, including their properties
  • Knowledge of trailer design and construction techniques
  • Experience with bolted connections and their load-bearing capacities
  • Research the load-bearing capacity of 3" square aluminum tubes with varying wall thicknesses
  • Investigate the strength and specifications of stainless steel cap screws for heavy loads
  • Explore best practices for trailer weight distribution and axle support
  • Consult professional engineers for safety assessments and design validation
Trailer designers, boat owners, engineers, and anyone involved in heavy load transportation who seeks to optimize trailer capacity and safety.
Chad Gilchrist
I need a little help on the redesign of our boat trailer, if you guys wouldn't mind giving a little advice. We have a heavy boat [we can assume the boat is 20,000 lbs], and we need to 1] increase the capacity of our axles, and 2] redistribute the loading of the weight. Currently, the weight of the boat is mainly carried directly on the axles. I would like to redistribute the weight to the main aluminum I beams on each side of the trailer, and then support the I beams with the axles. That will move the loading further to the outside of the axles, where they are better able to support the weight. Right now, the loading is too close to the center of the axle, causing them to bow too much. I made rough sketches of the trailer configuration for reference.
The red lines are the bungs that the boat sit on. The red circles are where the bungs are U bolted to the axles. The axles are 3" square steel tubes. The blue line is a 3" square aluminum tube that also supports the bungs, and the bungs are U bolted to this tube at the blue circles.
This is an end view, showing the loading of the bungs on the axles. We have to have the bungs in this position, due to water intakes and other features on the bottom of the hull. As you can see, this load should be positioned closer to the wheels in order to allow the axles to correctly support the load.
I would like to design, fab, and install 5 supports across the I beams for the bungs, and completely remove the bungs from the axles. Then I will support the I beams with the 3 axles. The new supports will need to be 3" square tubes, so the bungs will easily bolt up. Here are two possible ways to move the loading to the I beams. One is to run the new square support tube under the I beam, weld a piece of angle on each side, and thru bolt it to the underside of the I beam. The other is to run the new square support tube to the inside of the I beam, let the bottom of the beam support this tube, and weld a piece of angle on each side to bolt it thru the center vertical piece of the I beam. I am not sure which method would be stronger.
Assuming the boat is 20,000, and that we have 5 support beams, and that each beam supports the boat at two positions, I feel the problem can be summarized by the sketch below, where the red line is the new square suppport tube.
My questions revolve around what this tube needs to be to handle the loading. I would prefer aluminum, if it is strong enough, for the corrosion resistance. Can I go with 3" square aluminum tube with a 0.25" wall thickness? Do I need 0.375" wall? Or maybe even 0.500" wall? Should I steel for more strength?
Also, if I bolt the new tube underneath the I beam, the entire load will be supported by stainless steel cap screws. There will be 4 cap screws on each end of the support tube, supporting the 2000 lbs. What will 4 cap screws be able to support, if they are 1/2"? Should they be 5/8"? Or will it be significantly better to rest the end of the support tube on top of the bottom plate of the I beam?
You should not ask for any design work on this site. One, you may get horrendous advice wrapped up in a sensible answer. Actually, that is worse than blatant bad advice, which you would know to ignore. Bad things happen when you get backyard engineers involved in a project that will affect the public.
Your trailer you might say...
Will that trailer will be traveling down public roads? and break apart or careen into another car or worse a big yellow bus full of kids...
If you have to ask these types of questions, ask a professional.
Thanks for the advice.
  • · Replies 16 ·
10K
  • · Replies 16 ·
