What is the maximum speed achieved by a spaceship traveling to Moon Base I?
  • Thread starter Thread starter azila
    Hard Physics
The discussion focuses on calculating the maximum speed of a spaceship traveling to Moon Base I, given specific acceleration and time intervals. The spaceship accelerates at 19.4 m/s² for the first and last 14.4 minutes, while maintaining a constant speed in between. Participants clarify that acceleration is zero during constant speed and emphasize the importance of using consistent units, specifically converting time to seconds. A suggestion to use a velocity-time graph is made to visualize the problem and aid in calculations. Ultimately, the conversation highlights the need for correct unit conversion and the utility of graphical methods in solving physics problems.
azila
Another hard physics problem??
A spaceship ferrying workers to Moon Base I takes a straight line path from the Earth to the moon, a distance of 384000 km. Suppose it accelerates at an acceleration 19.4 m/s2 for the first time interval 14.4 min of the trip, then travels at constant speed until the last time interval 14.4 min when it accelerates at 19.4 m/s2 just coming to rest as it reaches the moon.
A. What is the maximum speed attained
B. What fraction of the total distance is traveled at constant speed
C. What total time is required for the trip
So, I made a table
X Vo V A t
First Time interval 2011.39 0 279.36 19.4 14.4
Constant Speed 379977 279.36 ? ? ?
Last time interval 2011.39 ? ? 19.4 14.4
First of all, is acceleration 0 when velocity is constant? If it is then in the constant speed time, the acceleration is zero and then the velocity would be the same. But I don't know how to get the max speed attained. What should I do? I tried using every one of the constant acceleration equations. When I tried solving for time, it was giving me 22 hours and that is not the answer. So please, if you can help me a bit out. Thanks
So, I made a table
X Vo V A t
yes, the acceleration is zero when the velocity is constant.
You seemed to have made a mistake with the units. You must put the time in seconds if you use an acceleration in m/s^2
it's good to make a graph for these types of questions..
then you really don't need to know any of those formulas ^^
for this, a v-t graph can help a lot
"I don't know how to get the max speed attained. What should I do? I tried using every one of the constant acceleration equations. When I tried solving for time, it was giving me 22 hours and that is not the answer. So please, if you can help me a bit out. Thanks"
ignore everything else, but this statement: " Suppose it accelerates at an acceleration 19.4 m/s2 for the first time interval 14.4 min of the trip, "
answer to your first question
Hint(if you trying graph way): Area of trapezoid = 0.5*v*(t when v is contant)*(t when v is contant+2*14.4)=total distance
Ok, thanks for telling me to convert the time in seconds because the time needs to be in seconds for the equation to work. Thanks rootx for the formula, I used that to get it. Yeah, graphing really helps. Thanks again for every ounce of help.
