Maxwell Ansoft to Excel: Tips & Tricks
Users are discussing the export of data from Maxwell Ansoft to Excel, with inquiries about using MATLAB code or Excel macros for conversion. One participant has extensive experience with Ansoft Maxwell for transformer simulations and is open to sharing insights. Another user requests a tutorial for simulating the magnetic field of two neodymium magnets in Maxwell, and a response offers to send a manual for a simple simulation. The conversation highlights the need for resources and shared knowledge among users of Maxwell Ansoft.
sara_UK
Hello guys
Does anyone use Maxwell Ansoft?
If so, have you tried to export it to Excell? if so do u use any MATLAB code to convert it? or use macros in excell?
Thanks
Hi All,
Did you export Maxwell data to Excell?
I am using Ansoft Maxwell for transformer simulations for all most a year and I have a lot of experience in real transformer production and projects. I am ready to share my experience...
Cheers
Alguem poderia enviar um tutorial simulando no maxwell o campo magnético de dois imas de neodímio?
Agradeço.
Could someone post a tutorial on simulating Maxwell's magnetic field two neodymium magnets?
ralecio@gmail.com
Thank you.
Hi ralecio,
I never did simulation for permanent magnets, but i will sent you manual. That is very simple simulation.
I hope that manual will help.
Cheers
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
