Understanding Mean Force in Tandem Steam Engines
The discussion centers on understanding the concept of mean force in tandem steam engines, particularly in relation to piston dynamics. A participant successfully applied the force-pressure relationship but seeks clarity on the underlying mechanics and the term "mean force." The diameter of the connecting rod (d2) is not provided, leading to assumptions that may affect calculations, although it is noted that its value does not impact the resultant force if pressures are equal. The net forces acting on the pistons are analyzed, revealing that the connecting rod's diameter does not influence the outcome when both piston chambers maintain the same pressure. Ultimately, a clearer phrasing of the problem is suggested to enhance understanding of the forces involved.
cwill53
Determine the mean force in a piston rod connecting pistons in two tandem cylinders of a steam engine if the diameters of the pistons are $$D_{1}$$=12.5 in., $$D_{2}$$=24in., the diameters of the piston rods are $$d_{1}$$=2.5in, $$d_{3}$$=4 in., and the mean steam pressures $$p_{1}$$= 135$$lb/in^{2}$$, $$p_{2}$$= 35.5$$lb/in^{2}$$, and $$p_{3}$$= 1.5$$lb/in^{2}$$.
$$p=\frac{\vec{F}}{A}$$
I found the correct solution using the equation that relates force and pressure, but I don't REALLY understand what the question is asking and what is actually going on in the machine. I want a better understanding of everything that's going on, not just an answer. Below is a clear diagram and a clear sheet of my work.
One issue I had was that the diameter of the piston rod d2 is not given. Maybe it was a typo? I don't know. But I made a guess and assumed that it was the average between d1 and d3. Another thing I don't get is what is meant by "mean force," and what exactly is happening in each section of the piston.
cwill53 said:
Homework Statement:: Determine the mean force in a piston rod connecting pistons in two tandem cylinders of a steam engine if the diameters of the pistons are ##D_{1}=12.5 ##in., and ##D_{2}=24##in.,
the diameters of the piston rods are ##d_{1}=2.5##in, ##d_{3}=4 ##in.,
and the mean steam pressures ##p_{1}= 135 ##lb/in2, ##p_{2}= 35.5##lb/in2, and ##p_{3}= 1.5##lb/in2.
Relevant Equations:: ##p=\frac{\vec{F}}{A}##
View attachment 261424View attachment 261425
You mention that for ##d_2## you used the average of ##d_1## and ##d_3##, but in your solution (by the way: It's very hard to read.) you used 3.25 in. for ##d_2##, which is not the average.
(Added in Edit: Of course you were right. 3.25 in. is the average of 2.50 in. and 4.00 in. )
Did you try using some different value for ##d_2## ?
For the mean force, you used ##(F_A+F_C)-(F_B+F_D)##.
Which of these terms depend on ##d_2##, or what you call ##A_{d_2}##?
Can you see what happens to any dependence on ##d_2##?
3.25 is (2.5in+4in)/2. The higher d2 is the lower the total areas would be for the calculations for Force B and Force D.
Oh yes! So it is. I need a new calculator.
As for ##(F_A+F_C)-(F_B+F_D)## :
Write that as ##F_A+ (-F_B)+F_C + (-F_D)##. Then write out ##F_B## and ##F_C ## in terms of the A's and p's .
Likes cwill53
This is not really important to the question, but in your relevant equations you gave ##p = \frac{\vec{F}}{A}##. This can't be right, since the LHS is a scalar and the RHS is a vector! A better relationship would be ##\vec{F} = p\vec{A}##, where ##\vec{A}## is the area vector of the surface (magnitude equals the area, direction is along the normal of the surface, i.e. ##\vec{A} = A\hat{n}##). Of course, the form we're first introduced to is just obtained by taking the magnitudes ##F = pA##.
Just thought you might find this interesting! It doesn't have any bearing on your working :cool:
Likes cwill53
I like the attention to detail, thanks for sharing that, I see it AS relevant as it’s always good to practice good habits!
Thanks for explaining area as a vector too, I was about to ask that as I was reading.
Likes etotheipi
Alright.
Can you help me understand what’s going on in the picture? I see what the object is, but I don’t have an intuitive understanding of what’s happening.
cwill53 said:
Alright.
I can try. However, if you actually do the regrouping I suggested, symbolically rather than after plugging in numbers, this all might be clear. I can't tell whether or not you did this.
An attempt at a little bit more physical explanation:
The issue here deals with:
FB , the force exerted (to the left, thus negative) on the right side of Piston #1 by steam at a pressure of p2
and
FC , the force exerted (to the right, thus positive) on the left side of Piston #2 by steam also at a pressure of p2.
As the figure and the given dimensions suggest, the the net effect of these two forces is that pressure, p2 acting on the right side area of Piston #1 exerts a force, FB, which cancels the force generated by p2 on an equivalent portion of area on the left side of Piston #2. The amount of force not canceled is just the force generated by a pressure of p2 acting on the remaining area of the left side of Piston #2. That area is ##\dfrac{\pi}{4}\left({D_2}^2 - {D_1}^2 \right) ##. This is independent of the area of the connecting rod, diameter d2.
In conclusion: The connecting rod subtracts the same area from each piston face discussed here and both of those faces are subjected to the same pressure.
Likes cwill53 and etotheipi
The question is worded in a way that's slightly bizarre to me. It appears a much clearer way of stating the problem is just "find the resultant force on the rigid body consisting of the pistons and the rod". All that remains to do is to compute the total force on this body, like you said \begin{align*} F_x &= F_{ax} - F_{bx} + F_{cx} - F_{dx} \\
&= P_1 A_1 - P_2 A_2 + P_2 A_3 - P_3 A _4\\
&= P_1 \frac{\pi}{4}({D_1}^2 - {d_1}^2) - P_2 \frac{\pi}{4}({D_1}^2 - {d_2}^2) + P_2 \frac{\pi}{4}({D_2}^2 - {d_2}^2) - P_3 \frac{\pi}{4}({D_2}^2 - {d_3}^2)\\
\end{align*} And then as @SammyS pointed out you get cancellation of the ##\frac{\pi}{4} P_2 {d_2}^{2}## terms.
This resultant force is going to cause the body to accelerate inside the cylinders, which will evidently change the pressures and result in a new resultant force. Hence our result holds only for this particular instant.
I might be missing something here but that is what I interpreted the question as!
Likes cwill53
and
I think it was more so the wording of the question that got me a bit confused. When the book says “mean force”. That just sounds weird. Thanks for the thorough explanation. After actually thinking about what the regrouping means and looking at the diagram it makes sense.
I interpreted this as having an external connection between the the two center chambers, keeping both at the same pressure, p2. Otherwise, as you point out, "our result holds only for this particular instant." In addition to that, knowing the diameter of the connecting rod would be crucial.
Likes cwill53
Yea I see now. This diagram looks like a simplified version of something that could happen in an engine. I screenshotted these pics from www.vintagemachinery.org and it looks just like the problem from the book
Likes etotheipi
That’s another thing that was weird. I assumed it might have been a typo that the diameter of the connecting rod was not given. Is there a mathematical way to determine the diameter of that rod assuming it didn’t happen to be the average of the two other rods?
Did you not understand after all?
If both of those portions of the cylinders are maintained at the same pressure as each other, then the diameter of the connecting rod does not matter. You get the same answer whether d2 is 0.01 in. or even the maximum possible, 12.5 in.
Likes cwill53
I see now, I took another look at the diagram and read what you said while looking at the diagram. The right side of the piston on the left and the left side of the piston on the right are both subject to the same pressure, but the forces caused by said pressure are acting in the opposite direction, I can just subtract the area D1 from D2, which will be in the positive direction because D2 has a larger area. Then just multiply that by P2 and add the positive and negative forces coming from Fa and Fd, respectively. Thanks for that. I know you literally said it several times.
I'd also like to emphasise that it makes no sense to talk of the force "in" a rod, only the force "on" a rod. The closest thing you'd get to a force in a rod is an internal force pair between two interacting mass elements, though that sort of thing is not at all relevant in this problem.
Sloppiness on the book's part!
Likes cwill53
I assume it’s because it was translated poorly. It was originally a Russian book, this was translated in the 60’s if I’m not mistaken.
Likes etotheipi
cwill53 said:
I see now, I took another look at the diagram and read what you said while looking at the diagram. The right side of the piston on the left and the left side of the piston on the right are both subject to the same pressure, but the forces caused by said pressure are acting in the opposite direction, ...
I did a search for tandem steam engines, then tandem compound steam engines. Learned some interesting things. Here's an image from the same site where you took your screen-shot, showing only tandem cylinder arrangement along with the steam flow and valving.
(http://vintagemachinery.org/MfgIndex/Images/4023-B.jpg)
In this position, the pistons are just beginning their motion to the right. So that as in the figure from your textbook the two central cylindrical cavities are held at approximately the same pressure. I found other aspects of these engines to be of interest, but I'll end this post here.
Likes cwill53
