Mechanics Of Materials Stress Problem
To determine the angle at which two rods experience the same normal stress, the method of joints is applied to solve for internal forces. The equations for equilibrium in the x and y directions are established, leading to expressions for the forces in each rod as functions of the angle θ. The tensile stress in each rod is calculated using the formula σ = Force / Area. By setting the stresses equal to each other, an equation for θ can be derived. This approach effectively leads to the solution of the problem.
Baumer8993
Here is a link to a picture of the problem:
http://imgur.com/5nOnpJE Click on the picture to make it bigger, and readable!I need to find the angle that the two rods will have the same stress. We are talking about normal stress here!
\sigma = Force / Area
I am using the method of joints to solve for the internal force because they are both two force members. I have the equations for x, and y.
X:
-AB + BC cos(θ) = 0
Y:
-50 + BC sin(θ) = 0
Where do I go from here? I want to start solving in terms of something to be able to put them into the stress formula.
In order to find the axial stress in each rod, you must first determine the axial force in each rod.
Steam is correct. However, does the load of 50 kN really matter if you want the stress to be the same? (just use F)
Draw a "joint diagram" and then find the force in BC as a function of theta, then the force in AB as a function of theta. Then continue.
X:
-AB + BC cos(θ) = 0
Y:
-50 + BC sin(θ) = 0
You already practically have it solved. Solve your two equations for AB and BC in terms of θ. The tensile stress in each of these members is equal to its tension divided by its cross section area. Set the two stresses equal to one another, and you will get an equation for θ.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
