Metal rod rotating in magnetic induction.
A metal rod of length 1/sqrt(pi) m rotates in a magnetic field of 5*10^-3 T, inducing an EMF of 1.5 mV. The problem requires applying Faraday's law to relate the induced EMF to the angular velocity of the rod. By considering a small element of the rod and its velocity in the circular motion, the total induced EMF can be calculated through integration. The solution involves determining the angular velocity (ω) to find the number of revolutions per second. Understanding these concepts is essential for solving the problem effectively.
amk_dbz
A metal rod (1/sqrt(pi)) m long rotates about one of its ends in a plane perpendicular to magnetic induction of 5*10^-3 T. Calculate the number of revolutions made by the rod if EMF induced between the ends of the rod is 1.5 mV.
I have been thinking about this problem for a long time but in vain. I just don't understand where to start.Any help will be appreciated.
Thanks
Faraday's law : EMF induced=- d∅/dt
I have tried using Faraday's law but can't figure out equation for ∅. I just don't understand where to start.Any help will be appreciated.
Thanks
Consider a small element dx of the rod at a distance x from the fix end. Suppose it is moving with a velocity v in the circular orbit.
Then the induced emf in this element dε = -vBdx. Put v = ωx.
To find the total induced emf, find the integration from zero to the given length of the rod.
In the problem emf is given. Find ω, which gives you the number of rotation per second.
Thank you sir/madam for your help.
