Modeling of Fluid(air) in ProE/ANSYS
  • Thread starter Thread starter adilsyyed
    Modeling
Modeling air for thermal analysis in a cabinet can be effectively done using ANSYS CFX, which is essential for coupled thermal and fluid analysis. Users are advised to utilize ANSYS Workbench for its ability to simplify models and fill volumes for CFD analysis. Importing models from Pro-E or other CAD software is recommended for better integration. For those new to ANSYS, it may be beneficial to seek subcontractor assistance or take courses on multiphysics problems. Proper setup involves creating a fluid region in Pro-E and importing it into ANSYS for analysis.
adilsyyed
Hello.
I want to do a thermal analysis of a cabinet having air. Its the temperature distribution I am interested in.
How can I model air, and mesh it.
I am a newbie to ANSYS.
So actually the questions are
1. Can I model air in Pro E
2. Can I model/mesh it in ANSYS.
3. Do I need Ansys CFX?
Honestly if you're new to ANSYS and don't understand the concepts and tradeoffs of FEA in general, you and your company are better off paying a subcontractor to do the analysis. That being said:
1) You're better off using ANSYS Workbench since it can fill volumes for the purpose of a CFD or emag analysis. Simplification of the model is key though.
2) You're better off importing the model from Pro-E or some other fully-featured CAD package.
3) Yes, CFX is one of ANSYS' CFD packages and will be required for a coupled thermal/fluid analysis.
Agree with Mech_Engineer,
If you are working on HVAC project, Airpack will be a good choice. And you can find similar tutorials, for quick start.
Thank you for the detail reply. It really helps.
And I am a student and it is a project.
Now I am doing the analysis in ANSYS CFX.
But just out of curiosity, what steps would you follow if you would do it in ANSYS (not Workbench)?
ANSYS CFX is only the fluid mechanics part of the code; if you're wanting to do a coupled thermal analysis you're going to have to couple with ANSYS mechanical.
Honestly there's just no way to explain how to do set up the kind of problem you're proposing through an internet forum. You're going to have to look at example applications in the ANSYS help and/or take a course in solving coupled multiphysics problems using the software.
I have installed Ansys multiphysics + CFX.
I am using Pro-E to model, then import it to ANSYS CFX Mesher, then ANSYS CFX Pre-, Solver and Post.
Am I doing it right?
To answer your question about modeling air (or any fluid region) in Pro/E, you can. I make a new part (usually a rectangular or cylindrical solid) that is large enough to enclose my fluid region. I then insert that part to the relevant assembly, and use the "cutout" component operation to remove the intersecting volume of the solid parts from the fluid part. I then import the assembly (or just the fluid part if that's all I need) into ANSYS and go from there.
Alternatively, there are methods of creating fluid regions in ANSYS DesignModeler as well.
