Modelling Salt and Water Flow in a Tank
  • Thread starter Thread starter DennisG
A differential equation is established to model the flow of salt and water in a tank, where 2 tons of salt enter a 20-ton tank of water each minute, while 2 tons of the mixture are drained simultaneously. The equation is represented as \frac {d}{dt} \frac {S^2 + W^2}{S+W} = \dot S, with W(t) indicating the water amount and S representing the salt amount, calculated as S = S_0 + \dot S \times t. The discussion also touches on uncertainty regarding the setup, with participants questioning the validity of their approaches. Clarification on the modeling process is sought, emphasizing the importance of accurate representation in differential equations. Overall, the conversation highlights the complexities involved in modeling fluid dynamics in a tank system.
DennisG
set up a differential equation to represent 2 tons of salt entering a 20 ton tank of water each minute while 2 tons of the mixture are drained each minute
where W(t) is the amount of water in the tank and S is the amount of salt given by S = S_0 + \dot S \times t with \dot S being the constant rate at which salt is added.
Are you sure about that tide? I could swear I tried that same thing, but I don't know, maybe I was just being an idiot. Thanks for the help
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
