Molar volume of gas in function of temperature and pressure
The discussion revolves around the possibility of two given relations for molar volume as functions of temperature (T) and pressure (P). The first relation, dv = R/P dT - RT/P² dP, is shown to be valid through integration, leading to the conclusion that v can be expressed as v(T,P) = RT/P + f(P), where f(P) is a constant. The second relation, dv = 2R/P dT - RT/2P² dP, raises questions about its validity, as the derived partial derivatives do not align as neatly. The mixed second partial derivatives for the first relation confirm its potential function status, while the second relation requires further investigation. Ultimately, the first relation is deemed possible, while the second remains uncertain.
damabo
Given are two relations for the molar volume. Are they possible? If so, give the formula for v in function of P and T.
a) dv =R/P dT - RT/P² dP
b) dv = 2R/P dT - RT/2P² dP
If I integrate dv I get ∫R/P dT - ∫RT/P² dP= RT/P + RT/P (in case a) and 5/4 * RT/P (in case b).
does this mean they are both 'possible'?
intuitively I would say only a is possible
another thing that struck me - probably resulting from some kind of error I made- was the following discrepancy:
say v=RT/P then dv=dv/dT dT + dv/dP dP = R/P dT - RT/P² dP.
So according to this v=RT/P might well be the solution to the integral ∫dv (in the case of a).
The molar volume v is function of P and T: v(T,P). If its first and second partial derivatives exist and continuous its differential is
dv=∂v/∂T dT + ∂v/∂P dp.
an the mixed second partial derivatives are equal:
∂(∂v/∂T)∂P=∂(∂v/∂P)∂T.
The integral of dv is independent of he path taken, v is a "potential", only if that condition holds.
In case of the first example, ∂v/∂T=R/P and ∂v/∂P=-RT/P2. The mixed derivatives are equal.
Now you have ∂v/∂T=R/P, and integrate with respect to T: V=RT/P + integration constant. But that constant can depend on P, so v(T,P)=R/P+f(P). You can find f(P) from the condition that the derivative of v with respect to P has to be -RT/P2:
∂v/∂P= -RT/P2+df/dP=-R/P2, so f=constant.
Check if the other dv can be the perfect differential of a potential function.
ehild
