Moment of Intertia of a cylinder rolling inside a cylinder
The discussion focuses on the moment of inertia of a smaller cylinder rolling inside a larger cylinder. The initial formula proposed for the moment of inertia around point o is I_o = I_s + m(R-r)^2, where I_s is the moment of inertia of the smaller cylinder. However, the correct moment of inertia is identified as 1.5 m(R-r)^2, indicating a misunderstanding in the initial calculation. The additional component arises from the smaller cylinder's rotation about its own axis while also rotating around the larger cylinder's axis. Clarification is sought on this concept to better understand the dynamics involved.
Elanorin
Hi all, I just have a troublesome time wrapping my head around the concept of moment of inertia of a cylinder inside a cylinder. For example, in the attached figure
The moment of inertia of the cylinder with radius 'r' around the point o, according to my understanding should be
I_o = I_s+ m (R-r)^2
Where
I_o is the moment of inertia around point o
I_s is the moment of inertia of the small cylinder = 0.5 m r^2
m is the mass of the small cylinder
I believe my understanding above is wrong, since the actual answer is 1.5 m (R-r)^2. Any help to clarify is appreciated.
I think that there is an additional component caused by the fact that the smaller cylinder would also be rotating about it's own axis at the same time it is rotating about the larger cylinder's axis as well.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
