How Do You Calculate Force in a Momentum Problem?
  • Thread starter Thread starter street
    Momentum Student
To calculate the force exerted on the wall by the ball, first determine the change in momentum using the equation ∆p = m∆v, where m is the mass of the ball and ∆v is the change in velocity. The ball's mass is 2.5 kg, with an initial velocity of 8 m/s and a final velocity of -7 m/s (since it rebounds). The impulse-momentum theorem states that F∆t = ∆p, allowing you to solve for force as F = ∆p/∆t. With a contact time of 0.2 seconds, you can substitute the values to find the force. Understanding these concepts is crucial for solving momentum problems in physics.
street
Hi. I just recently switched into a physics course midyear, and I really don't know what's going on. Help with a few of these questions would be greatly appreciated.
A 2.5 kg ball strikes a wall at 8 m/s and rebounds at 7m/s. The ball is in contact with the wall for 0.2 seconds. What is the force on the wall?
Im really not sure. Is this it?
F?t=?p
F(1)?t=m(1)v(1,f) - m(1)v(1,i)
F(2)?t=m(2)v(2,f) - m(2)v(2,i)
I'm not sure how to apply that information into the equations, and I'm not even sure if the equations are right.
Please help
Please help
I don't see why you introduced all those 'initial' and 'final indices', since the only thing you have to know and apply here is that impulse equals change in momentum. You know the definition of impulse, and you know the initial and final (if you like it better) momentum.
F∆t =∆p ?
I still don't understand how to do it.
street said:
F∆t =∆p ?
Yep. and ∆p=m∆v
So, F∆t=m∆v
Finding F... F= m∆v/∆t
street said:
F∆t =∆p ?
Define the final and initial momentum. The change in momentum is represented by the difference between the final and initial momentum.
