Calculating Stopping Distance of Car with 0.45 Frictiongrade
To calculate the stopping distance of a car with a friction coefficient of 0.45, moving at 18 m/s and weighing 1200 kg, the friction force is determined to be 5.5 kN. Using the work-energy theorem, the initial kinetic energy of the car is calculated as 0.5 * mass * velocity squared. The equation 0.5 * m * (vo)^2 - f * (delta x) = 0 is used to find the stopping distance, where f represents the friction force and delta x is the stopping distance. By solving for delta x, the distance the car travels until it stops can be accurately determined. This approach effectively applies the principles of physics to solve for stopping distance.
Izekid
Here it comes, I have a frictiongrade who is 0,45 A car who is driving in 18m/s and mass of the car 1200kg
For the Frictionpower it is : 0,45 * (mg) = 5,5 kN
And how do I calculate the meters the car travels until it stops?
initial kinetic energy - work done by friction = 0
(1/2)m(vo)^2 - f(delta x) = 0
solve for delta x
Use the work-kinetic energy theorem. That is the work done by all of the forces acting on an object (or the resultant of all of these) is equal to it's change in kinetic energy:
W_{F_R}=\Delta K
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
