What was the relationship tested in the running shoe ramp experiment?
  • Thread starter Thread starter jefflincoln
    Motion Ramp
The experiment tested the relationship between the angle of inclination of a ramp and the motion of a running shoe, specifically examining how increasing the angle affects the forces acting on the shoe. As the ramp's angle increases, the gravitational force parallel to the ramp increases, leading to acceleration when this force exceeds friction. Additionally, the normal force acting on the shoe decreases as the angle of inclination rises. This interplay between gravitational force, friction, and normal force is crucial for understanding the shoe's motion. The experiment effectively illustrates the principles of static and kinetic friction in relation to incline angles.
jefflincoln
I'm writing a lab that pertains to a running shoes motion down a ramp and calculating the coefficient of static and kinetic friction. We placed a running shoe on a ramp and increased the ramps angle of inclination until the shoe began moving down the ramp.
1.Is it correct for me to say that as the angle of inclination increased the force of gravity parallel to the ramp increased, therefore the shoe accelerated in this direction when it outmatched the force of friction ?
2. what type of relationship was being tested in this lab?
Yes, but there's a little more to it. As the ramp is tilted, what is happening to the normal force?
