Multivariable calculus question
3 replies · 3K views
engineer_dave
Sketch the following curves on separate number planes.
y= 2x^2
x^2 + 2y^2= 4
For the first one, would the intersection of the curve with the y-axis be at y=2 ( I have attached a diagram of my solution). The minimum point would be at (0,2)?
For the second one, what do we do with the 2 which is the coefficient of y^2. Would the 4 be the radius of the circle.
Thanks in advance.
In the first one. If the curve was intersecting the y-axis, then x = 0 at the point of intersection, and so y = 0 aswell, so it intersects are (0,0). Also, the minimum point of the function is at (0,0).
For the second one, are you sure that the equation you have describes a circle? I would call it an ellipse myself.
oh alrite, but then what happens with the 2 in x^2 for the first equation. Yea, the second one is an ellipse so would 4 be the radius?? Cheers
[tex]y = 2x^2[/tex]
if x = 0; [tex]y = 2*(0^2) = 0[/tex]
As for the ellipse. have you tried working out the values for x and y when the other one is set to 0? That will tell u where it crosses each axis.
edit: This might help - http://en.wikipedia.org/wiki/Ellipse
