My group has given the task of modeling projection of line and my
The discussion revolves around a project involving the modeling of line projections using two mirrors. One proposed idea is to connect the mirrors like a laptop, allowing them to be folded and positioned perpendicularly. Concerns arise about how to securely attach the mirrors without damaging them, particularly when considering drilling holes. An alternative suggestion is to use wooden mounts with hinges to avoid drilling, while another idea involves using duct tape as a hinge, although this raises concerns about potential damage to the mirrors. The conversation emphasizes the need for a practical and safe method to achieve the desired functionality.
ajayguhan
My group has given the task of modeling projection of line and my part is to construct the vertical and horizontal plane.
So my idea is to have two mirrors joined like an laptop, so that we can fold them and they can also be perpendicular.
I'm thinking of making hole in one mirror and a hook in another one , so i can insert the hooks into the hole and therefore i can rotate one mirror with respective to another.
The problem is how can insert the hooks into the hole, if it was plastic it would be flexible to bend and we can insert both hokes, in case of mirror how can we?
Is there another better way to do it...? I
why not mount the mirrors on two pieces of wood and hinge the wood pieces together? That way you don't have to drill a hole in one of the mirrors.
Good idea thanks...! But is there way to make with mirrors any suggestions, you have?
the cheapest thing is to use duct tape (aka duck tape, gray tape) taped along the backs of the mirrors as a sort of hinge. I'd worry about removing the duct tape afterwards removing some of the mirror backing and ruining the mirror.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
