Need help on rotational dynamics problem quick please
The discussion revolves around solving a rotational dynamics problem involving an inverted "A" structure suspended by two vertical ropes. The key points highlight that the system is in static equilibrium, meaning the net force and torque must equal zero. Participants suggest using the formula W=Fcosd to find the force applied by the crossbar to each leg, but there is confusion regarding the displacement measurement, questioning whether it should be in meters instead of the given length. Clarity on the dimensions and understanding the equilibrium conditions are essential for solving the problem. The conversation emphasizes the importance of correctly interpreting the problem's parameters to proceed effectively.
Crazedkid
hi i need help understanding what to do with the information that was given in the problem if u could point mein the right direction i would greatly appreciate it. thank you
An invered "A" is suspended from the ceiling by 2 verticle ropes. Each leg of the "A" has a length of 2L and a weight of 120.0N. The horizontal crossbar has a negligable weight. Find the force that the crossbar applies to each leg.
Known:
W=120.0N per leg
l of legs= 2L
angle at top of "A" = 60Degrees
l of crossbar=L
I think the key idea here is that the system is in static equilibrium. That means that the net force and torque are zero. Can you take it from there?
Parth Dave is right. The system is at rest so the net force is 0. If that is not the case read below.
the formula is W=Fcosd
but what doesn't make sense is that you don't have the displacement. Are you sure it says 2L not 2m.
