Need help with computing the volume of a solid by revolving lines
db2dz
the directions are:
compute the volume of the solid formed by revolving the given region about the line
region bounded by y=2x, y=2 and x=0 about (a) the y-axis; (b) x=1
V=∫A(x)dx,a,b
From what my teacher showed in class this is how i think it is worked out
(a)
V=∫A(x)dx,0,2
=∫(pi)[r(x)]^2,0,2
=∫(pi)[2x-2]^2,0,2
=∫(pi)[4x^2-a],0,2
=(8(pi))/3
so i am not sure if this is right or if i have to times(8(pi))/3 by 1/3 because the volume of a cone is (1/3)(pi)(r^2)(h)
and i don't know where to begin on (b), i think when it is revolved it will be Cylinder with a cut out. please help
You want to think about what a cross section of solid perpendicular to the rotation axis. In this case, it's easier to integrate dy than dx, since that's the rotation axis. The volume is then integral A(y)*dy where A(y) is the cross sectional area at y. In a) the cross section is a disk? So yes, the area is pi*R(y)^2. What's R(y) as a function of y? In b) the cross section is a disk with a hole in the middle (a 'washer'), but it's the same general idea.
so i used dy to integrate and for a i got 2(pi)/3 which i think is right because i checked it with V = (1/3) π r² h. But i am not sure how to get b. i know its a cylinder with the cone removed and i think its volume is 4(pi)/3 but i still have no idea.
You are right. To get b) using integration the cross sectional area is area of an outer circle minus the area of the inner circle that was removed. So it's pi*(outer radius)^2-pi*(inner radius)^2. Integrate that dy.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
