knight92
- 100
I carried out a wind tunnel test on two radiators. Radiator 1 is a small radiator and radiator 2 is a bigger radiator with nearly twice as much volume and area as radiator 1.
Flow rate going into radiator 1 is 1.2L/min
Flow rate going into radiator 2 is 1.5L/min
the problem is radiator 1 dissipated more heat than radiator 2. Considering the larger area of radiator 2 I would have thought it would dissipate more heat, so the water entering at 90 degrees Celsius should exit at a lower temperature in radiator 2 at say a air speed of 8m/s but it doesnt.
My conclusion is that the radiator 2 did not get filled up completely due to the small flow rate. Can you guys input your opinions on why this might have happened ?
other than thinking the radiator wasnt getting filled up completely, I can't really figure out for the life of me why it would not cool the water more than the smaller radiator 1.
thanks
thanks
