Net Electric Field due to 2 different charges
To find the point where the net electric field is zero between two charges of 0.600 nC and 9.60 nC separated by 1.60 m, the electric fields created by each charge must be equal. The user attempted to set the electric fields equal using the formula E = kq/r^2 but arrived at an unreasonable distance of 9.58 m. The discussion suggests setting up an algebraic relation to balance the electric fields, indicating a need for a more accurate approach to determine the correct distance. Additionally, the impact of a negative charge on the net electric field's zero point is raised, implying a different calculation method may be necessary. A clearer understanding of the relationship between the charges and their distances is essential for solving the problem correctly.
Ahmad1129
A. Two particles having charges of 0.600 nC and 9.60 nC are separated by a distance of 1.60 m. At what point along the line connecting the two charges is the net electric field due to the two charges equal to zero?
B. Where would the net electric field be zero if one of the charges were negative?
E= kq/r^2 k= 8.99X10^9
I am really lost about where to start. Using the two charges and distance of 1.6m, I calculated the electric field to be 2.03X10^-8 N/C
You can imagine that in between the two particles, there's a point at which the influence of one particle exactly balances that of the other. Call the distance from this point to the 0.6 nC charge "d". Can you set up an algebraic relation that states "this charge must create the same electric field as this other charge"?
so, should I set the electric fields due to each charge equal to each other and solve for d?
maybe, E1= kq1/d^2, E2=kq2/d^2 and so kq1/d^2=kq2/d^2 and d=square root(kq1+kq2)
I did this, but I get d to be 9.58 m, which doesn't sound reasonable
Is there a better way of doing this?
