Net Work Done on 15.8kg Block: 51907.724 J
A 15.8 kg block is dragged over a rough surface by a 90.9 N force at a 28.6-degree angle, resulting in a displacement of 22.8 m and a coefficient of kinetic friction of 0.18. The work done by the applied force is calculated as 1819.637 J, while the work done by friction is -456.886 J. The net work done on the block is incorrectly calculated initially due to an unnecessary multiplication by displacement. The correct net work should be W_net = 1819.637 - 456.886, resulting in a value of 1362.771 J. The discussion highlights the importance of careful unit consideration in work calculations.
DollarBill
A 15.8 kg block is dragged over a rough, horizontal surface by a constant force of 90.9 N
acting at an angle of angle 28.6 above the horizontal. The block is displaced 22.8 m,
and the coefficient of kinetic friction is 0.18.
What is the net work done on the block?
W=F d cos(theta)
Work done by the 90.9N Force:
W=F d cos(theta)
=90.9*22.8*cos(28.6)
WF=1819.637 J
Work done by friction:
W=F d cos(theta)
W= friction * d * cos(theta)
W=u Fn * d * cos(theta)
W=u(mg-y component)*d * cos(180)
W=.18[(15.8*9.8)-90.9sin(28.6)]*22.8 * -1
Wf=-456.886 J
Wnet=WF-Wf * d
Wnet= 1819.637-(-456.886) * 22.8
Wnet=51907.724 J
You have a sign error in your second to last line. You are also multiplying the net work by d. I don't know why you are doing this. Your second to last line should read:
W_{net}=1819.637-456.886
The negative sign comes from the cos(180) term. You do not need to add another one in this line.
As I said before, you also shouldn't multiply by 22.8 in your second to last line. I don't know why your doing this.
Does this make sense?
1362.771 J
I'm not sure why I multiplied it by d again. I guess I forgot to look at the unit and thought they were forces. Thanks.
